Oxygen Sensor Placement
Discussion in 'ECU's, Electronics, and Tuning' started by mauger, Mar 24, 2003.
  1. mauger
    mauger Junior Member
    where do you put the 2 nd o2 sensor in a header or can you weld a bung i the cat? i have a 91 civic with a b16a w pr3 ecu
  2. riceboy
    riceboy Member
    Dallas
    you can put a bung in the cat
  3. pissedoffsol
    it technically should go AFTER the cat on the cat for best reading
  4. D See 2
    D See 2 Senior Member
    Baltimore, MD
  5. Larryd
    Larryd Junior Member
    :rolleyes: You should put the second bung at the same relitave spot as the sensors in the cast manifold. The computer reads the mixture in two pair of cylinders. The also have to be in the corect order. I think white plug is no 1.....Larry
  6. legutki
    legutki Senior Member
    i going through the same problem except im using a b18c w/ obdo injectors and dist. and a skunk2 intake manifold . the b18c only has i sensor before the cat.
  7. D See 2
    Baltimore, MD
    how could the computer tell which sensor was infront of which?... i think for the pr3 ecu, both o2 sensors should be relatively close to one another.
  8. D See 2
    Baltimore, MD
    here it goes loud and clear for ya... taken directly from a b16a1 crx manual... using an obd0 pr3 ecu... notice where the two oxygen sensors are placed? in the same fucking spot! getting readings from the same place.
  9. legutki
    So if you buy a new header your best bet would be to put one in the cat?
  10. D See 2
    Baltimore, MD
    right before the cat.
  11. legutki
    Is there hi flow cats with holes already in there. i know there is a stock cat from a 95 gsr for sale and it has a o2 sensor on it. whats the performance diff between a stock and a hi flow?
  12. wildbillhatchbac
    wildbillhatchbac the OG VIP
    OBD1 1 o2 sensor . . . in the manifold, before the cat
    OBD2 2 o2 sensors . . . 1 in the manifold and the 2nd in or after the cat
    OBD2 ecus can read the difference between pre cat and after cat exhaust oxygen levels . . . if you have no cat or even some high flow cats will or can through a code . . P0420 catylist deterioration
  13. legutki
    I found out that pr3 can be reprogrammed to read only one o2 sensor. for more info look at gbrtuning.com or email greg at vtec4gs@aol.com :D
  14. D See 2
    Baltimore, MD
    yea, hondata can also do that, its called making your ecu run in open loop mode. a closed loop mode will read both oxygen sensors.
  15. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    i thought open loop didn't use O2 sensors at all??>???
  16. D See 2
    Baltimore, MD
    exactly, open reads none, and closed(stock setting) reads both
  17. pills_PMD
    New Albany, OH
    but he said that you can reprogram it to read ONE o2 sensor.. and you said hondata can do that and make it run open loop. nevermind lol
