P08 , 1 wire 02 and z6 harness
Discussion in 'ECU's, Electronics, and Tuning' started by bistec, Jan 27, 2007.
  1. bistec
    bistec Project EH23
    I've just swaped in a d15b. Right now i'm using a p28. My car is a 93 del sol si (had z6 before swap). The harness is the z6 one. Can I use the p08 ecu that came with the engine knowing that the z6 02 ssensor plug is for 4 wires. If yes how can i wire the 1 wire 02 sensor. I have to use the 1 wire 02 sensor because my exhaust manifold is cracked with my 4 wire 02 sensor that can get out of it:( . I got a new mani and don't want to buy an other 4 wire 02 sensor.
    Thanks.
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    to use the po8 ecu you need to use the 1 wire 02 just find the signal wire on the harness and splice into it
  3. bistec
    bistec Project EH23
    I've ordered a 4 wire 02 sensor. Since this car is my dd, can i use the 1 wire o2 sensor with my p28 ecu for a couple of days until i recieved the 4 wire one? I can't use the po8 ecu right now because i have to convert it to auto first. Thanks!
  4. AHHVTEC
    Alabama
    well you can but it will have a check code and make it run weird
  5. bistec
    bistec Project EH23
    CEL light but nothing unsafe?
  6. AHHVTEC
    Alabama
    well realy its 50-50 i wouldnt do it
  7. bistec
    bistec Project EH23
    Then i won't do it. I'll just sacrify more bucks and get the 4 wire o2 sensor localy.:(
    Thanks for the help and advice:thumbsup: !
  8. AHHVTEC
    Alabama
    just go to a junk yard and get any honda 4 wire o2
  9. bistec
    bistec Project EH23
    Great! I will.
