My P13 Auto ECU only has three plugs, A, B, & D. No C. Just like all the rest.
Unless you have some funky ECU, you shouldn't have traction control that I know of.
There is a code list in my sig. Code 36 isn't on it.
I'd try another ECU, borrowed from a friend. See if you get the same code. If not, replace yours. If you do happen to get the same code, which I doubt, then start scratching your head again.
