p28 and P13 chip
jam05pr
Member
Hey everybody,
I just got a quick question. I have an h22 with a chipped p28 computer. I want to change the chip I currently have because it has been giving me problems with the oil pressure switch. I was just wondering if the p13 chip is the same size as the p28 chip. If not, how do I go about getting a p28 chip that has an h22 program on it.
Originally posted by pissedoffsol@Mar 24 2005, 03:21 PM
p13's are a bitch to chip and is not commonly done. frankly, theres no point in doing so.
if you want a p13 PROGRAM for your p28, that can be done easily.
http://www.pgmfi.org/twiki/pub/Library/Ecu...P13_USDM_C2.bin
burn that program on a chip, plug it in the p28. done.
[post=478141]Quoted post[/post]​
Not exactly.....
You need to start with a P28 base then build it to P13 specs.
Or you can use a P72, but you'll need to add the IAB hardware and remove the knock sensor info.
I dont want a p13 computer I was just wondering if the chip size is the same because when I go to buy one I dont want to get a p13 chip if it is not going to fit.
[post=478509]Quoted post[/post]​
No, it's not the same.
