p28 chipped for a jdm d15b vtec swap
92civy
is p28 good ecu, what chips should and can i use i plan on boost (8 psi) in the future.
i have did some look up on ebay and there are a couple chips like, where the speed governor is diable and the rev limiter is moved to like 8500-9300 rpm and some make vtec kick in @4400-5500. 5 different ones.
i looked atr these ones: http://cgi.ebay.com/ebaymotors/P06-...sspagenameZWDVW
are these good/ comes with p06 converted to p28 with 5 chips
+1 for phearable. if you already have the p28, id also shoot chris from xenocron.com an e-mail and see if he can burn you a map.
