P28 question
EG6_down5hift
I heard a chipped P28 or P30 will power a GSR? true? how would it look for IABs?
a chipped ecu can be made to power just about any car, i had a p28 chipped with iab's for my h22 so you should be able to get one to work for gsr.
yes it is true... there was a thread previously about adding IAB control to a p28. try a search for it.
also the p28 will not check for a knock sensor, but the p30 will.
kyle, you should check out the new wiki. The nitroburn one is read-only now after the move.
http://wiki.pgmfi.org
New wiki has new look and also context-sensitive attachments. look for a lot more pictures after I can afford a digicam. :)
