p28 vs. p30
Discussion in 'HYBRID -> EG-EK / DC' started by 93cxhatch, Dec 7, 2004.
  1. 93cxhatch
    93cxhatch Senior Member
    Seattle, Washington
    I have a b16a1 and I am trying to do the wiring I was wondering if the p28 and p30 ecus have the same pinouts??? Also If there are any differences in the two ecus?
  2. civiclxb16
    civiclxb16 Senior Member
    Poconos pa
    same pinouts since they are both obd1 ecus the difference is the fuel mapping and the knock sensor which is meant for the dohc the p28 is for a sohc vtec and the p30 is for the dohc vtec
  3. qtmac_mien
    qtmac_mien Senior Member
  4. pissedoffsol
    we have similar diagrams and pintouts here.
    http://www.hondaswap.com/forums/index.php?showtopic=29360
    p30 and p28 are identical pinouts. the p30 has 1 extra, for the knock.
    if you can, run the p30. it will give you much better fuel map, correct vtec activation points, and was frnakly, designed for that motor.
  5. BrowNKiD
    BrowNKiD Member
    Toronto, Ontario, Canada
    does the same thing apply for a b18c5 motor...cause im running a p28... and it works fine... but does the p30 give more hp?
  6. Slammed90Lude
    Slammed90Lude Senior Member
    milford, PA
    you're running an unchipped P28? ideally, if it's an OBD 2 car you should be running a P73
    otherwise, you're losing power on a stock P28
  7. chicken
    chicken Senior Member
    Sacramento, California
    its an obd1 car.. run the p30..
  8. Slammed90Lude
    milford, PA
    :werd:
    i was owned by not reading the topic title :p
