DaNnYsEvEn7
ive been searching every where i can and i still cant find info on this.
i have an obd1 dohc zc in my ef, right now its running on a p75 ecu. im going to be getting a p29 ecu which is the correct ecu for the motor. i have heard that the p29 does not use a four wire o2 sensor, but there was a way to use a 4wire o2 sensor and wire it up so it works with the p29 ecu. anyone have any info on this? other than that will the p29 plug up without having to change anything else over? it has an obd1 jumper harness.
thanks guys
thanks guys
