hello, i'm runnin a D16 with a (P29 ECU), i swapped a B16A2 under the hood, the engine came with its wires that r stick on it, i plugged it to the wire ( located near the fuse box near the fender) it started but the vtec is not working check engine is always on( though i tried to rewire it,but no use ) and i guess the ecu (P29)needs to b remapped, its not pumpin fuel as rich as it should, and cutoff around 7800RPM.
PS( i know i shouldnt do that but i needed to drive it since my other ride is ruined)
So i guess what i need is the wires that goes from the engine to the ecu,and a P30 ECU or any good alternative ECU,a MAP Sensor and an oxygen sensor.
plz if any has what i need or can help let me know,thanks
