ok I just did a 98 JDM h22a obd2 swap with a JDM P5M obd2 ecu in my 96 hatch. Problem is that I cant even crank the motor with the ECU. I had the same problem with the PCB ecu. Both of the ecus are JDM obd2's sent from HMO. All the wiring should be correct, cause the motor starts and idles when I used my friends obd1 p72 w/obd2-1 harness.
I was wondering if these obd2 jdm ecu's use a pin security or emobalizer of some sort or is this really rare?? Arrgghhh! Any help, links or info. will be greatly appreciated! thanks
