p72 ecu with itr head
Discussion in 'ECU's, Electronics, and Tuning' started by ngq, Oct 19, 2002.
  1. ngq
    ngq Member
    my buddy is installing itr head & itr intake manifold on his b18c (gsr) .Will
    his p72 ecu do the job without problems.
  2. AllMotorMonster
    AllMotorMonster Senior Member
    Inland Empire foo!
    Technically? Yes, but a chipped P28 or a stock P30 would be better.
  3. chris
    chris Senior Member
    nihon
    it will work, but the vtec cross over will be too low for that head, also the ecu will be looking for that secondary butterfly.
  4. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    is he aware that the ITR IM wont' bolt up to that head without some welding, drilling, tapping??
  5. ngq
    ngq Member
    the itr head has its intake manifold on it already. is that still a problem?
    vtec cross over too low is that bad for motor or performance.
  6. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    Not really. The ECU will work fine. I am running a B16 head with ITR cams and a P72 ECU. THe XOver is a little low because the motor bogs when VTEC engages. The ECU doesn't care that the secondary butterflies aren't there.
  7. pissedoffsol
  8. bte15
    bte15 Senior Member
    Bellevue, Washington
    wierd are you sure it is a obd2 p72 i am sure you are but still wierd
  9. ngq
    ngq Member
    the ECU that came with my jdm 97 b18c (sir)37820-p72-013
    its obd2 for sure. should i expect it to bog with p72. is there any other
    alternative like 97 p30 obd2.
  10. lsvtec
    Mine is OBD1, I don't know if the OBD2 throws a code when you don't have the secondary butterflies, but the OBD1 doesn't care.
    EDIT: I'd be willing to bet that the OBD2 doesn't care either because the Skunk2 manifold does not have secondaries and it doesn't cause the ECU to throw codes.
  11. ngq
    ngq Member
    no after market support in jordan means i have to stay p72 obd2
    and wait for p73 .
  12. speedborn
    speedborn New Member
    If you change the low RPM Vtec engagement reprograming the ECU, andf the ECU does not care about the two stage butterfly, there should not be any problems right?
  13. eg6sir
    wow, just wow... 5yrs old dude
  14. ls94civic
    ls94civic New Member
    vermont
    Quit thread jacking nood
