p73 ecu?
Discussion in 'ECU's, Electronics, and Tuning' started by emoney, Jan 14, 2005.
  1. emoney
    emoney Junior Member
    hi guys... i know this might sound like a dumb question, but this is my first swap. ok i have a 96 gsr and i just swapped in a 2000 itr motor and tranny. i have an ecu w/ code # 37820-p73-a04 on it but it doesn't hook up. i m not sure if its some knock off ecu or what, it says keihin corp. on it. anyway, i just want to know whati need to get the car on the road. a new itr ecu? wiring harness? any help is more than welcome!
    thanks
  2. 94RedSiGal
    94RedSiGal Senior Member
    Massachusetts
    nfn15037 says to use a 97-98 ITR ECU with your swap. B)
    Edit: It's still a P73 ECU but it's an OBD2a instead of what you are trying to use... and OBD2b (which also has an imobilizer built into it). You'll see that a OBD2a one will have the right plugs on the side for your wiring harness.
  3. pissedoffsol
    yep-- you're trying to use a 98+ usdm b18c5 itr ecu on it.
    see what you got here:
    vs your old ecu
