I know that both are b18b heads but what is the diffrence. Is it the OBD. Which one is obd1 and which one is obd2. Also, Are the bare head's interchangeable.
correction, not all p75 heads are from b18's, some came from b20's like the ones found in the crv and others came from jdm b20's out of honda orthia's. i got all this info off honda tech so you can check there extensive b20 thread. but basically it states that the b20 heads from honda orthias have larger intake valves but are still stamped p75.
but as far as i can tell they have the same cam as a b18b and they are both stamped p75.
Originally posted by saturn_boy96@Jul 23 2003, 11:33 AM correction, not all p75 heads are from b18's, some came from b20's like the ones found in the crv and others came from jdm b20's out of honda orthia's.
