Boosted199
ok well i got bored and wanted to paint my valve cover ive done paint jobs before on my actual car and it comes out fine but when i went to do my valve cover the paint didnt stick it jus like cracked up and dripped like crazy i call it spider web cause das how it looks like a spider web as if it shrunk and cracked id what i did wrong... first i used paint stripper the spray den hosed it down sanded the valve cover did like 2 coats of primer let it dry then since i was doing a 2 color theme i painted the letters the color i wanted 2 coats let it dry then tapped over the letters and did the base coat but where the letters were around it the paint cracked and spidered idk whats wrong please help i no there is probly a tread explaining this but id appreciate any advice and help thanks in advance... oo and i was using spray cans not a spray gun if that helps...
