Painted Interior...Help!
Discussion in 'Body / Exterior / Interior / Cosmetics' started by 801CRX, Mar 13, 2008.
  1. 801CRX
    801CRX Got Rice?
    UTAH
    Alright lets get it started, first off im not painting the dash.
    Here is my question, How in the hell do I get paint off of my CRX interior panels and dash?
    I bought the CRX like this and I want to get rid of this ricey sh*t. I thought about paint stripper and the more common means of removing paint. But don't want to hurt the dash and panels any more than I have to.
    Any help is very appreciated!!!
  2. eg6sir
    its a shame when you get the ricer aftermath... probably be better to replace the entire dash
  3. LS_VTEC
    LS_VTEC you get the BRAKE
    NJ
    Nailpolish remover will do the trick, but it will be very time consuming. Just go easy with paint thinner and a soft brush.
    1 person likes this.
  4. 801CRX
    801CRX Got Rice?
    UTAH
    ^^^Tell me about it my first rex was riced on the outside, with an awsome completely stock interior...this one was an easy fix, its just to bad it was jacked!
    Now this one has a riced out interior, with an OK exterior.
  5. 801CRX
    801CRX Got Rice?
    UTAH
    Never heard of that, guess ill try that on a little area to see how it turns out.
    Thanks for the info, you get a rep:)
  6. LS_VTEC
    NJ
    Thanks. Let us know how it turns out. Like I said, its time consuming. Good luck.
  7. Jeef
    Jeef NO MA'AM Moderator VIP
    Nail polish remover is pretty much acetone which you can probably get a home depot or any paint store.
  8. 91_civic_si
    91_civic_si New Member
    Wasilla, Alaska
    Just paint it black. Chances are you will mess up the material if you remove the paint.
  9. INJEN78
    INJEN78 HS LEGEND
    OHIO
    for the hard plastic pieces..get a rag and aircraft stripper(walmart has it) pour the stripper on the pieces and let it set for like2-3 minutes..then get to scrubbin with the rag..just dont leave it on too long..it will eat the platic over time...
  10. Z6CRX
    Z6CRX übber ɐɾuıu etarip
    Pittsburgh, PA
    I've also had luck using brake cleaner on harder plastic parts, but a good idea to test any cleaner on a small spot so it doesn't ruin the whole piece.
  11. Jeef
    Yes do test spots. Don't use anything to strong as it can melt your panels. IS the paint in good condition or is it peeling off? If its not peeling and is relatively smooth I would use so will bond (liquid deglosser) and just paint over it.
  12. Z6CRX
    Pittsburgh, PA
    brake fluid works better than brake cleaner, just remembered that. A friend of mine soaked his center console in that when it was painted silver, and took a toothbrush to scrub it off as to not damage it.
