painting valve cover
Discussion in 'Body / Exterior / Interior / Cosmetics' started by K2e2vin, Aug 26, 2004.
  1. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    ive looked at DIY painting valve cover, and in all of them the crinkled look is removed. is there any way to paint the valve cover and retain the crinkled look?
  2. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    paint over the stock paint or get it powder coated with crinkle paint
  3. Relix
    Relix Junior Member
    Before
    after
    I grinded off the DOHC Vtec logo and used Tempo" Black Wrinkle enamel
  4. K2e2vin
    Raleigh, NC
    thanks guys. ive searched around for blue wrinkle paint but couldnt find any. right now my paint somehow cracked off so i have to repaint the whole cover. do i just buy black wrinkle paint and just paint over that?
  5. hcivic.com
    you cannot just use enaml paint it will come off over time you need high temp paint
  6. tab
    tab Super Moderator
    Aberdeen, Washington State
    I had good luck before with wrinkle paint. My local paint store had it in a can. You spray it on like normal paint, then bake it. The longer it cooks, the more it wrinkles. I top coated it with black high temp paint.
    It stinks like a motherfucker for about two weeks, but eventually fades away.
    :shrug:
  7. hcivic.com
    that smell is the enaml burning off and leaving the high temp on there
  8. 90 accord
    90 accord Chicks dig the box Moderator VIP
    Mesa, AZ
    i used aircraft stripper to remove my old paint, then used some 1200 degree engine paint.. it still has the faint wrinkles.. can;t really tell in this pic, but i'll take a fre more if you'd like..
  9. K2e2vin
    Raleigh, NC
    nah its fine. ill try that wrinkle paint. but thanks anyways.
  10. hcivic.com
    do want a flat or gloss finish
  11. K2e2vin
    Raleigh, NC
  12. hcivic.com
    ill shot one tommorow and post pics
