Parking my car for winter
Discussion in 'Members' Lounge' started by hunter4life, Dec 9, 2008.
  1. hunter4life
    hunter4life Rotary Man
    Canada
    Okay so I want to park my car for the winter. I was just wondering what I all have to do to it, before it goes in storage.
  2. TurboMirage
    burn it to the ground :)
    1 person likes this.
  3. reckedracing
    reckedracing TTIWWOP VIP
    NY
    get some gas treatment
    helps to fill the gas tank to keep condensation from forming over and over again
    also helps if you start it once a month
    i never do, but its a good idea
  4. hunter4life
    Canada
    I'll make sure antifreeze is good too, but thats what I thought...just didn't know if there was anything else that might help it....and no I DO NOT want to burn my baby to the ground lol...She's pretty much mint, I want to keep her for a long time.
  5. Briansol
    i pull it into the garage.
    that's about it.
    i run it every now and then when its nice out, i'll take out for a spin.
  6. dacheat
    dacheat ..is grounded.
    strongbadia
    yeah you don't wanna let it sit for months on the rubber. if you're truly putting in storage, put it up on blocks or jacks, keeps from wrecking yer tires. won't have to do this though if you run it around once a monthish, which is good for the seals and whatnot anyway. ;)
  7. Briansol
    plz drive me before i go bad. :(
  8. hondasaurus
    hondasaurus Member
    VA/DC
    disconnect batt. clean and cover it.
  9. E_SolSi
    put it in a parking lot with the keys in it and a sign saying please return by __\__\__ (the date you would like it back)
  10. dacheat
    strongbadia
    :lmao:
    also lol, but not as damn cute as that seal was.
    when seals go bad....live at 11. :ph34r:
  11. hondasaurus
    hondasaurus Member
    VA/DC
    club sandwiches not seals
  12. team_spoold
    team_spoold New Member
    under the arch in good ol MO
    i know when my close friend was deployed on a year tour in iraq and he put his 350 up on on jackstands in his storage unit and used gas treatment and lowered all fluid levels before takin off and he had someone go and take it down every so often whe it was nice out and take her for a spin around the block and did usual maitnence.
  13. hondasaurus
    hondasaurus Member
    VA/DC
    how long until you start it up again? bet that rotary will blow smoke when first turned on.
  14. D15Beater
    D15Beater HNFTuning
    Concord N.C.
    Or since its a honda you can pull the drain plug outta the tank and drain it. You didnt say what model it is so I dont know. Not all of them have drain plugs. you could also run it outta gas..
  15. INJEN78
    INJEN78 HS LEGEND
    OHIO
    the OP as an rx7,
