Loco Honkey
Banned
Here's what's NOT for sale:
Everything else is for sale!
Here's a list...
-engine mounts
-shift linkage
-front LCAs (for those of you without front sway bars)
-front sway bar (w/ mounts and end links)
-radiator
-radiator fan
-evap canister
-throttle cable
-clutch master and slave cylinders
-front calipers
-brake master cylinder
-pedal assembly
-dashboard
-HVAC controls
-power mirror switch
-dash dimmer switch
-dome light
-rear hatch area light
-rear defroster switch
-fuse box
-car harness
-any other wiring inside the car
-heater blower fan
-gauge cluster
-pristine airbag steering wheel
-every interior bit you can imagine
-moon roof (has cracked glass, though)
-almost- new axles
-rear hatch glass w/ wiper motor and arm (defroster works!)
-rear tail gate w/ or w/out inner tail lights
-outer tail lights
-seat belts
-steering column
-steering rack (w/ good tie rods)
-front spindles (good bearings and ball joints)
-front upper control arms (w/ good ball joints)
-COMPLETE AC SYSTEM W/ LINES (this will bolt into ANY 5G Civic) (buy this and I'll include the HVAC controls at no cost)
-hood
-left and right fenders
-stock 14" steelies without tires
-rear hatch struts (no leaks)
-rear 1/4 windows
-left and right doors
-power mirrors
-D16Z6 intake manifold complete with injectors, sensors, fuel rail, and TB
-D series starter
-D series alternator
-D series power steering pump (w/ lines and resivoir)
-D series ACT flywheel 8.3 lbs
-D series six copper puck sprung hub Clutchnet clutch (20 spline disc)
-and lastly, Rota Slipstreams sized 16X7 with a 4X100 pattern and a 40mm offset. They're Roytal Steel Grey, which is a silver that's a few shades greyer than normal "silver" wheels, and they have a polished lip. They come with three good Kumho 712 tires sized 215/40- 16. I can either remove the tires at your expense, or sell you a new fourth 712 at whatever the going rate is.
So I can stay organized with this many parts, PLEASE DO NOT PM ME OR POST HERE! Email me at houseofboost@yahoo.com and put Re: (name of part you want) in the subject line and in the body of the email, put your zip code, and I'll email you back within 24 hours with a price shipped. I'm located in Middlebury, VT, and ship with DHL. If you post here or PM me, I won't reply.
Code:
Engine, transmission, springs, front seats, rear disc swap, interior door panels, and exhaust, engine harness, ECU, headlights, corner markers, front and rear bumpers.
Here's a list...
-engine mounts
-shift linkage
-radiator
-radiator fan
-evap canister
-throttle cable
-front calipers
-pedal assembly
-dashboard
-HVAC controls
-dash dimmer switch
-dome light
-fuse box
-car harness
-heater blower fan
-gauge cluster
-almost- new axles
-outer tail lights
-seat belts
-steering column
-hood
-rear 1/4 windows
-power mirrors
-D series starter
