parts for lower
Discussion in 'Wheels / Suspension / Tires / Brakes' started by whiterice91, Oct 31, 2007.
  1. whiterice91
    whiterice91 New Member
    do i only need lowering springs and some new shocks to lower my car? and if i need shocks what kind
  2. norcalgsr
    NorCal
    What kind of car and how much money are you planning to spend?
  3. klyph
    klyph Dismember VIP
    North Pole, AK
    Actually, all you need is a hacksaw. What you'll want will depend on a few personal preferences.
  4. norcalgsr
    NorCal
  5. whiterice91
    91 civic h/b, and i know where i can get some lowering springs for cheap, but ill spend 400 if i have to
  6. norcalgsr
    NorCal
    You can get a set of Tokico blues for around $300 or so.. you don't have to buy shocks, but if you put lowering springs on the stock shocks they will blow out eventually. If you save a little more money a set of KYB AGX adjustable shocks can be had for around $400.
    You could probably get cheaper prices than those if you look around too.. I just searched real quick for prices.
  7. 91_civic_si
    91_civic_si New Member
    Wasilla, Alaska
    cheap springs = a shitty ride
  8. norcalgsr
    NorCal
    That's true for the most part.. but if you match the spring rate of the springs to the right shocks it will ride ok most of the time unless you're buying pure garbage.
  9. 91_civic_si
    Wasilla, Alaska
