Parts Polooza! Little Bit of Everything. Help me fund my LSVtec.
unsivil_audio
Ninja's pwn samuri's.
Got a bunch of honda/turbo/misc parts laying around. If you don't see it here ask. Alot of d-series parts, flywheels, misc bolts, crank girdles, even a couple blocks.
USED Polyurathane inserts (driverside mount) - $15 shipped
EG Cruise control/dimmer/sunroof switch - !$12 shipped
D16z6 bare block, timing tensioner bolt snapped off in block - $50 shipped as is or $85 shipped tomorrow when I rehone the cylinders and slap a fresh coat of black paint on it.
z6 old pan, untapped, silver overspray on it - $35shipped
z6 valve cover, silver overspray - $35 shipped
OBD0 LS fuel rail and FPR - $35 shipped
Random parts piles.
DSM o2 housing, got two of them - $15 shipped ea.
OBD 0 D-series dizzy, no cap - $30 shipped
D15b7/z6 IM, Bare - $30 shipped
b18 LS Fuel Rail - $15 shipped
d15b7/d16z6 no-name Spark Plug Wires - $10 shipped
B7/Z6 Fuel Rail with fpr, send, and return lines - $15 shipped
OBD1 LS Integra engine harness missing one plug, I think its the o2 sensor - $50 shipped
Cheapturbolines.com 14b/TD04/TD05 oil line kit, missing return hose and oil pan brass barb fitting. Can get that fitting from ACE hardware and the hose from NAPA - $55 shipped
OBD1 240cc injectors - $25 shipped
P28 92-95 cruise control unit - $40 shipped
b7/z6 oil dipstick, rubber stopper needs to be glued in place - $10 shipped
4-wire o2 pigtail- $12 shipped
Sold
Daiken/Exedy Stage 1 Clutch Disc and PP, never used, no alignment tool but I can probably find one if need be. - $SOLD
d15b7/d16z6 NGK 8mm spark plug wires, good condition - $Sold
LS crank pulley, good condition - $Sold
92-95 White face indiglo guages - $Sold
B7/Z6 oil pan, untapped - $Sold
B-series stainless headflange - $Sold
OBD1 d16z6- $Sold
1st set - LS rods, ARP rodbolts - $Sold
2nd Set - PR4 LS Rods - $Sold
Like I said earlier, I have tons of miscellaneous mounts, shift linkage, intake parts for both d-series and b-series motors, alot of EF parts too. If anybody is interested in the a/c components for an EF I got it all, so LMK. All prices are OBO, so lowball the shit out of me, let get these parts off my bedroom floor. Thanks alot guys.
I've got quite a few vouches between Turbod16.com , Honda-tech, and Homemadeturbo. Thanks again.
-Joel
what blocks you have? im looking for either a b16 block or a b18 block. complete or not just let me know what you have and how much.
No b-series blocks, sorry.
I'm adding some more parts tonight guys which include. Z6 valve cover, OBD0 LS fuel rail, another z6 oil pan, so keep watching.
It was just a d15b7 non-vtec head. I stuck a JDM SOHC ZC cam in it though, supposed to be just as good as the D16a6 cam.
Ah, ok. The SOHC ZC cam is actually a bit more aggressive than the A6 cam- it has more exhaust duration, and more intake/exhaust overlap.
