passenger cv axle will not go into the Hub???
Discussion in 'Civic and CRX - EF' started by TravisCadello, Aug 10, 2008.
  1. TravisCadello
    TravisCadello Banned
    Houston,Texas
    Ok, I worked on this fucker for 2 hours and the drivers side slid right in and i hammered the rest in. the passenger side for some reason will not go in for the life of it! i feel the lines or threads in the center of the brake rotor and their fine. and i look at the cv axle and the little stripes or threads are good maybe a barely little messed up. i put grease and hammered it as hard as i could while spinning the hub. do i need a new cv axle or what??:(
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    the hub is different from a std civic and other models. is yours a std ?
  3. red91efhatch
    red91efhatch New Member
    Albuquerque
    I was thinking the same... fit it outside first, and when it comes to sliding the axles in it hsould be nmore about finesse then force.
  4. TravisCadello
    Houston,Texas
    Yes, Its standard, but what werd is their the same axles i was using before and the sam transmission and it still wont go it. its like somethings stopping it. but if i take the axle out the tranny and hammer it in on the outer side of the hub it goes in no problem. its werd if it goes in on the opposite side then i'd think it should go in the other side no problem. what else could this be???
  5. AHHVTEC
    Alabama
    no clue put something on it to lube it up good,
  6. TravisCadello
    Houston,Texas
    i put a ton of wheel bearing grease and still didn't go in. I'm gonna try in buy a new axle for that side its all screwed up anyways.
  7. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    You shouldn've have tried to hammer it in. The splines probably aren't lined up or it's a little crooked.
  8. TravisCadello
    Houston,Texas
    Thats what i thought thats why i tried spinning the hub and hammer softly and it never would find a path to go in. its like somethings blocking it.
  9. K2e2vin
    Raleigh, NC
    I had that issue with my Accord. Patience eventually paid off(took a lot of wiggling and spinning). You should clean the splines and inspect them.
  10. TravisCadello
    Houston,Texas
    i cleaned them greazed them and everything. i took 2 hours of trying and trying. i think im gonna buy a new axle. hopefully that works.
  11. K2e2vin
    Raleigh, NC
    Good luck! If that doesn't work, maybe the splines on the hub is messed up.
  12. TravisCadello
    Houston,Texas
    In that case would i have to replace it all?
  13. efhondakid
    Akron-Canton, Ohio
    Yes, if something is messed up and cant be fixed what do you usually do next?
  14. K2e2vin
    Raleigh, NC
    It would be easier to just replace the whole knuckle with a known good one but a shop can press in new hubs pretty easily. You can change your wheel bearings while you're at it. If you have a HF/Std and plan on swapping motors in the future, might as well swap in DX/Si/EX knuckles and axles.
  15. TravisCadello
    Houston,Texas
    whats the diffrence in the si axles?
  16. AHHVTEC
    Alabama
  17. K2e2vin
    Raleigh, NC
    The DX, Si, and EX hubs use larger ends(larger diameter/more splines).
  18. TravisCadello
    Houston,Texas
    and if i swapped them would the Si axles fit my D- series tranny?
  19. AHHVTEC
    Alabama
    the hub axle holes on the std are larger than the others
  20. TravisCadello
    Houston,Texas
    And these wont help me at all as of now but only later on down the road right? or are they stronger and better?
