PCV valve causing idle problems??
Discussion in 'General Tech and Maintenance' started by bdogggut34, Jan 4, 2005.
  1. bdogggut34
    bdogggut34 Senior Member
    I have been idling about 300-400 rpms and havent been able to adjust it by the screw. Thing is, the engine is a 95 B18b but has a newer B18/B20 valve cover on it with a PCV valve hole. I have put a PCV valve in there but the other end of the hose is just floating because i noticed on the stock 95 valve covers there is no hole for a PCV valve. Is this the idle problem and how would i plug that hole??
