Pedals and Misc.
Discussion in 'HYBRID -> EG-EK / DC' started by torturedsol, Dec 28, 2006.
  1. torturedsol
    torturedsol New Member
    I've read through many threads doin my homework before I start my swap. I've got a 93 Del Sol Si....automatic (barf). A friend is giving me his wrecked 91 Teg GS. I plan on using the motor and trans out of the teg for my swap after I rebuild it.
    My main question is: Will the pedal assumbly from the 5-speed teg bolt in to the del sol?
    Yes, I plan on keeping the cable clutch...nothing wrong with it + I like them lol
    I belive I have everything needed for the swap:
    Pedal assembly
    shift linkages
    wiring harness (if needed)
    ecu...not sure a p75 will help much since, iirc, a chipped p06 will work a B-series fine.
    I've got a whole parts car....anything is better than a d16 with an auto =-p
