thanks but now i need to now if it needs the cam angle sensor to run it.
to let you get i little insight im doing a dpfi to mpfi conversion on my crx and i need to know because im using the same harness out of my civic which was running a d16a1 and now its running some thing else but the a1 was runing a vacum advanced dizzy and this one is not.
this ecu is the electronicly advanced version so do i need to run a a6 dizzy or not
