pgm fi relay help
Discussion in 'Civic and CRX - EF' started by Somalia757, Jan 25, 2008.
  1. Somalia757
    Somalia757 SOMALIA
    VA BEACH, VA
    I have to replace the pgm relay under the dash and I don't have a Manual. Does anyone know where its located under the steering column? I have a 91 civic hatch dx with a ls vtec. Also does anyone know how many prongs are on thud one for my car I need to know so I can get the part after work so I don't have to drive home pull the relay and go to the parts store
  2. 93civicracer
    93civicracer Oh, I do a little here and there.
    Texas
    Try to find a relay from a junkyard, brand new they'll cost you around $50 even for an older Civic at least around here anyway. I got mine from a junkyard when mine went bad, and I only paid $5 for it along with some spare fuses I pulled with it.
  3. Somalia757
    Somalia757 SOMALIA
    VA BEACH, VA
    Thanks guys I figured they were the same but the lady at the auto parts store asked how many prongs and added confusion for me.
  4. 93civicracer
    Texas
    So unplug it, and count the prongs.
  5. Jeef
    Jeef NO MA'AM Moderator VIP
    I was never able to find them at an auto parts store. Just go to Honda to get one. You do not have to remove the hood release, atleast I never did. If you search and are good with a soldering iron there is a way to fix yours.
  6. YBLEGAL
    YBLEGAL Regular Member w/ Cheese
    NW Indiana
    i told him how in his other thread on the same topic....
  7. Somalia757
    Somalia757 SOMALIA
    VA BEACH, VA
    I replaced the relay and still had the same problem then checked all the sensors it ended up being a wire that came loose on the back of the intake manifold connected to the green sensor idle air control valve I believe. The wiring sucks from whoever did it.
  8. YBLEGAL
    NW Indiana
    yeah that sucks. wiring issues are a pain in the butt.
