m90polk
I have a 90 hatch with a zc installed and the other day i replaced the tranny so i took the whole engine out and disconnected the engine wiring harness from the car wiring harness and put the engine back in then hooked everything back up. Also I have a kill switch hooked up to the PGMFI relay (one wire to the black ground one and one to the yellow power wire), when I try to start it up i disable the kill switch and turn it on the relay will buzz and the check engine light will flash rapidly. So the car won't start now but I had it started and running before the tranny swap, any help is appreciated.
