Phantom Grip Limited Slip Differential Conversion
Discussion in 'General Tech and Maintenance' started by mrnice1058, May 5, 2004.
  1. mrnice1058
    mrnice1058 Senior Member
    Pa
    Phantom Grip Limited Slip Differential Conversion Kit. what do you guys think of it?
  2. swanny
    swanny Senior Member
    buck teeth and government checks, PA
    Waste of money. They are known as "phantom slip" Save and buy a Quaife.
    clutch/viscous/torsen action = a real lsd
    binding up the spider gears = not a real lsd
    Want to read up? http://auto.howstuffworks.com/differential.htm
  3. Havok
    Havok Senior Member
    Florida
    :withstupid:
    Phaton Grip, in laymens terms is not a real LSD.
    I think Phantom Grip is the only option for D series...and it's better than nothing, from what I have been told, but not worth the money.
    If you got a B series tranny, def. get an ITR LSD or Quiafe
  4. phunky.buddha
    Dallas / Fort Worth, TX
    Nope, you can get both OEM and aftermarket LSDs for the D series transmissions.
  5. turboB20hatch
    turboB20hatch Senior Member
    pacific nw
    i have a phantom grip on my LS bseries tranny and it works great.
    if u do choose to go with phantom grip make sure u get the spring tuning tool.
  6. mrnice1058
    Pa
    i have a b series tranny so what exactly does the phantom do and how do i get my hand on one those real lsd's?
  7. phunky.buddha
    Go read up on Phantom Grip's site.
  8. mrnice1058
    Pa
    i know what they are supose to do but what i want to know is where can i get my hands on one of the "real"lsd tranny parts anyone know??
  9. swanny
  10. mrnice1058
    Pa
    dam 2g's there is no way i can just get the differental and install it on my b16 tranny?
  11. phunky.buddha
    Buy a Quaife for $850 and put it in.
  12. turboB20hatch
    pacific nw
    ive seen jdm ctr/itr lsd's sell for below 300 on ebay and those just replace the differential inside your b16 tranny and shabangalang you got LSD... a way better 1 than the phantom grip but still comparable to queef ? quaife ? whatever
  13. phunky.buddha
  14. mrnice1058
    Pa
    ok i know this is long this is an email i got from two of my friends what i want to know about is the viscous technique is this true all you need is thick ass fluids and you are good? and will it work? i mean for the mean time until i can save up for the "real"lsd?
  15. phunky.buddha
    My transmission is from a JDM SiR2 (not a Type R) and has the gear based Torsen LSD. The clutch LSDs were generally in pre-94 Integras and pre-92 Civics. Most other OEM Honda applications from those periods on up use gear based limited slip diffs.
    The viscous LSD is still an LSD- you can't just put thick fluid in your transmission and expect it to operate like an LSD. It uses alternating plates with grooves cut into them- the grooves run cross-wise to each other from plate to plate. The fluid acts on these grooves to make the plates resist turning against each other, and that's what produces the limited slip effect.
  16. mrnice1058
    Pa
    dam i want to grow up and be just like you thanks man that info kicked ass barely inderstood it but it sounds dam good....lol nah i got it basically stop being cheap and get the good stuff i will keep my eye out on ebay for them but first i need to get my engine in and running good then i will go for all that i just figured since my engine is out i could do it but i see the phantom is not worth the money so i will wait...
  17. phunky.buddha
    If you want to "grow up" to be just like me (and nobody should), you should try to use proper spelling, capitalization, punctuation and grammar. People will be more likely to help you if they can understand your posts.
    If you want to get your engine back together with a Phantom Grip you can- just be careful to install it correctly. For the same price though, you should still just look out for an OEM LSD to install into your transmission. Most engine suppliers actually only charge a $300 premium for the OEM LSD option on a Honda transmission, so you might be able to sell the transmission you have right now and just buy another one. That would save you the hassle of trying to pull your transmission apart and installing an LSD- there's more involved than just dropping it in.
  18. Bl6CRX
    Bl6CRX Senior Member
    UCLA
  19. mrnice1058
    Pa
    DAM IT! (is that better) I just sold my Tranny and got a LS tranny it took me like 4 weeks to get this all done i wish Steve would have told me that about the LSD, but i guess i didn't notice that is my fault for not doing the proper research thank you Master your apprentice is learning
  20. phunky.buddha
    It's cool. :)
    Why did you get the LS transmission? What did you have before? I guess Steve is the one who's doing your engine work, right?
