pics of my turbo setup
zap45
here are pics of my turbo setup going on my f22b dohc
here the progress so far i will post more when i complete it.
Also looking for a downpipe with a sharp angle bend so that it wont hit alternator
eBay turbo and mani is the reason you are looking for such a sharply bent downpipe. If that's all you have, I'd say return it and start over, man. I'm not trying to be a dick here, I'm just saying that eBay shit doesn't hold up unfortunately.
i got the intercooler pipe to i think this turbo will work for a basic setup i not returning nothing i should noe post pic of this if i gonna get negative feedback
I'm just letting you know the reason why you are going to be searching for a specific downpipe. I had an eBay setup that was going to be going on my car, and decided against it after I bolted it up and found that there was little room for my downpipe, let alone a dumptube for the wastegate. Good luck, you're going to have some fitment issues, man.
Oh, and it's not negative feedback, its criticism. I've done this already.
Mutha' phuckin' :werd:
To the OP your only choice is to fab your own pie-cut DP.
that what im trying together is the downpipe im only gonna run 7psi nothing exciting but i will get that downpipe figured out next i got to get is wastegate, ecu bigger injectors the whole works thanks and sorry ;)
Well at least buy a decent wastegate so the boost doesn't spike on ya.
Best gates out there are any TiAL or Synapse. Both can be had for 200-300$ new or cheaper used. Good luck.
and what boost controller do you recommend?
You dont need a boost controller, just get a spring.. they make 7lb springs and just tune it to run off the wastegate.
Turbosmart is also a great brand. around the same price range. Go with the 38mm ultragate. I never get boost spike with it.
