pics of swap
Discussion in 'HYBRID -> EG-EK / DC' started by h22bubbleback, Sep 23, 2003.
  1. h22bubbleback
    h22bubbleback Senior Member
    North Jerzey
    mount is off 92 teg. doesnt fit on my 1st gen b16 into an EG .. :wtf: even took left bolt out to turn it..still wont fit :angry:
    ALSO:....
    bolt missing on the bottom of the solenoid. wut is it for? does even a bolt that goes there? :shrug:
  2. SixtySecondAssassin
    Austin, TX
    you need mounts from a 94+ teg
  3. h22bubbleback
    North Jerzey
    im not sure..but aint 94 plus teg mounts not offset. my bracket pattern is offset
  4. Canuck 93 Civic Si
    Canuck 93 Civic Si Senior Member
    Mississauga, Ontario, Canada
    just crowbar that shit. itll fit fine :lol:
  5. h22bubbleback
    North Jerzey
    crowbar wont even work..when i actully got the mount to sit inn the holes dont line up. like the mount is twisted to much..doesnt seem bent thou
  6. TurboMirage
    you need the mount from the 94+ teg. its a sister chassis.
  7. noobvang
    noobvang Senior Member
    Twincities, MN
    For your Vtec Solenoid, what you are missing is the vtec oil pressure sensor. Should be a green plug that goes there.
  8. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    You've got the right mount and bracket, but it looks like your bracket is twisted forward, possibly from whatever wreck helped it find it's way into the junkyard.
    Here is mine, and that is the D series mount on the B series bracket.
    And about the 94+ teg mount, you are correct about them being straight, you have to change to a 94+ bracket when using them.
    No, the oil pressure is higher and more to the rear, that is the ECT (engine coolant tempurature sensor.
    Seen here is the both of them.
  9. MrLewis84
    MrLewis84 Junior Member
    i WOULD TRY CHANGING THE BRAKET PART THAT IS STICKING OUT OF THE MOTOR....USE ONE FROM AN INTEGRA......WHEN PUTTING AN LS MOTOR INTO MY ek CIVIC I HAD THE SAME PROBLEM AND I PUT THE BRACKET FROM AN SI ON THE LS MOTOR AND IT WORKED...I WAS TOLD THAT IF MY CAR WAS AN EG THE LS MOTOR WOULD HAVE WENT IN PERFECTLY, MEANING THE EG CHASSIS'S HAVE MORE IN COMMON WITH INTEGRAS THAN THEY DO WITH EK CIVICS ..MAYBE DOING THE OPPOSITE MY WORK FOR U...GET THE INTEGRA BRACKET
    .....I KNOW IT SOUNDS CONFUSING
  10. xj0hnx
    C.C.TX.
  11. h22bubbleback
    North Jerzey
    got the 94 teg bracket n it fit perfectly. i didnt even have to pry it in
  12. noobvang
    Twincities, MN
    :blink:
    Not sure what you are saying, but green plug is the same spot as his last pic he posted.
  13. xj0hnx
    C.C.TX.
    You're right (Noobvang) I must have been on crack when I posted that.
