Can anyone show the pin out for the 88-91 PW0/PR3 .I did a swap then add a turbo with large injectors ,so I am putting a apex S-AFC to control the injectors but I neeI have a PW0 ecu and i did a swap turbocharged I am using some large injectors so I need to know the pin outs of the ecu so I d to know which wires to cut and tap into.Need help urgent.
how doyou numbers the pins on the ECU that is to know which wire to connect the S-AFC to, when the OBD0 ECU looks like this when the ECU is facing you. see the ecu at www.zdyne.com then click on TECH and to the right of the screen you will see 3 ecu the one i am talking about is the one at the bottom OBD0
