pinchin the fuel line
civiclxb16
ok explain this to me we still didn't get the civic running right. so what we did was change the fpr it was a used one so i don't know how good it was, so my buddy said turn the key and he pinched the fuel return line and boom it started what could it be? and what does it mean?
Originally posted by TWISTEDIMAGE@Mar 23 2005, 11:15 PM
i think i am correct
but
when you pinch the return hose you are building up more fuel pressure
[post=477845]Quoted post[/post]​
Yes that is what it would do in effect. It would be close to the same thing as running the FPR without any vacuum source, just more drastic.
sounds like to little - when you pinch the line raises pressure pumps faster- expand the line lower pressure pumps slower !
Originally posted by reckedracing@Mar 24 2005, 04:00 PM
mmm, fuel pump wouldn't build enough pressure either way, i think its your regulator...
[post=478162]Quoted post[/post]​
If the fuel pump is dying, it could be pumping very little fuel, in which case it would take a pinch in the line to raise the pressure up enough. FPR is easier to check though. I recommend AEM.
