Pins A6 And A11
Discussion in 'ECU's, Electronics, and Tuning' started by Vexamus, Feb 13, 2003.
  1. Vexamus
    Vexamus Member
    Quick questions, pins A6 and A11 have to be swapped when swapping to any other engine than the F22B1 in the 5th gen accords...
    My question is, which side is it backwards? Is it backwards at the ECU?(i.e. if I keep the current engine and harness but change to another ecu will I have to switch them).
    OR
    Is it backwards in the wiring harness?(i.e. I'll have to switch the wires when I get both a new engine and new ECU.)
    Please reply quickly.
  2. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    i guess i dont understand your question? what are you swapping in and waht are pins a11 and a6??
  3. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    Well, think of it like this:
    If you drop an H22 into a 5th-gen Accord and use the H22 computer, that computer wants to read the heated O2 sensor from wire A6 and the EGR valve from wire A11. But on the HARNESS, A6 is the EGR and A11 is the heated O2 sensor.
  4. Vexamus
    Vexamus Member
    I'd get a check engine light if they were backwards when I put my p30 in on my F22B1 with the ACcord harness. Right?
  5. dohcvtec_accord
    The left lane
    Yup, probably. What's a P30 ECU from?
  6. Havok
    Havok Senior Member
    Florida
    wtf?
    A P30 is from a DOHC VTEC Del Sol...
  7. Vexamus
    Vexamus Member
    ok, well maybe I wouldn't. I checked with some charts on Hondata, it's backwards on the ECU(P0A). Because when you buy a Hondata ECU you have to switch them around even if you're using the Accord Harness on an F22B1, you still have to switch them around. That could be why it's running like ass...
    I only ask cuz I was testing the functionality of the Mugen P30 I bought for the H. I figure they're close enough that I'd get some sort of idea of how it'd run the H. I'm going to go swap those wires and see what happens.
  8. Vexamus
    Vexamus Member
    it's been remapped to run an H, relax. I'm not THAT new.
    I am however, going to get the Hondata s200 for it ASAP! I need more control!
    hehehe. Think my P0A would control the H22A enough to make it to work and back?
  9. dohcvtec_accord
    The left lane
    Kinda. I've tried it. It sucks when the P0A kicks VTEC at 2500 rpm and the H22 cams say "What the FUCK?" :D
  10. Vexamus
    Vexamus Member
    but I can get by without the knock sensor?
  11. dohcvtec_accord
    The left lane
    Yeah, as long as your timing isn't messed around with and you're running premium gasoline.
  12. Vexamus
    Vexamus Member
    Straight, I just took apart my P30, I'll be doing the s200 installation myself since about 95% of it's already done. 28-pin socket 74hc373 ic's been installed J1's been bridged, there's already a 1.1Kohm resister in R52. The only thing I have to do is install a couple of capacitors and I'm golden.
