piston pin driver
Discussion in 'General Tech and Maintenance' started by Arachnid, Oct 5, 2004.
  1. Arachnid
    Arachnid Senior Member
    doing a piston swap and can't find no where where i can get the driver set for cheap. anything around 100 is nice. does anyone know the website/store/etc where i can get this item. i've tried snap-on but with no luck. maybe someone else might know a few more tricks as to what goes into the search. thanks!
  2. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
    It is called a mallat. you have to heat the pistons up so that they expand, and put the pins in and let the piston cool. I was able to do this all by hand as the piston expanded enough to do this, however I am told that is a rare experience. Personally if you have not done this before I would have a machine shop do it for you, or have someone who has done a honda pistons help you out.
  3. Arachnid
    you mean rod right? the wrist pins go in fine into the piston.
  4. Slammed90Lude
    Slammed90Lude Senior Member
    milford, PA
    no he means piston dude
  5. Arachnid
    there's no need to heat up the piston. like i said the piston pin will glide on it. why would you need to heat up the piston. it's the rod that the pins have to be pressed into. so.....anyone have any idea where to get the driver kit.
  6. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    it called a wrist pin
  7. Arachnid
    please no useless posts. we all know it's either wrist pin or piston pin(helms manual) ok.
  8. hcivic.com
    do a search for wrist pin
    and you need a press to get them in
  9. Arachnid
    see....i have a 12000lbs (6ton press). i can't find the damn driver set for the wrist/piston pin.
  10. hcivic.com
    got to a machine shop and have them trun you one itll cost 60 buucks at most for 1 hr labour
  11. Arachnid
    i'm a serious do-it-yourselfer. so i don't really want to go to the shop unless there's absolutely no other option.
  12. hcivic.com
    no have the machine shop make you a set of pin drivers!
    i made my own on the lath didn't take very long
  13. Arachnid
    oh yeah *ding. yeah but the piston base, head, spring, shaft and other special tools for driving the wrist pin in...i'll need those too. seems like i'll have to buy a kit or something.
  14. hcivic.com
  15. Slammed90Lude
    milford, PA
    you're going to need the following parts from honda:
    Piston Pin Driver Head- #07973-PE00320
    Piston Pin Driver Shaft- #07973-PE00310
    Pilot Collar- #07LAF-PR30100
    Piston Pin Base Insert- #07GAF-PH60300
    Piston Base Head- #07HAF-PL20102
    Piston Base- #07973-6570500
    Those are the part numbers honda lists, i'm sure they're not all necessary, but even so, it's gonna be a bit more expensive to DIY then it would be to just take it to a shop- your call
  16. Arachnid
    yeah, but this won't be my only build. if it's a reasonable amount like around 100 or so for the set then i'll get it but if it's rediculously expensive then forget it.
  17. hcivic.com
    the parts i made worked great and cost me 0
