Piston Question
Discussion in 'General Tech and Maintenance' started by uneek187, May 22, 2003.
  1. uneek187
    uneek187 Junior Member
    how do you remove the piston arm from the piston some1 told me there is a really small pin im woundering thanks on a 90 civic dx engine.
  2. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    If you don't own a hydraulic press you can't do it yourself. It has to be pressed out.
  3. uneek187
    oh can you rent that tool or no?
