Piston Rings: OEM Vs. Hastings Vs. NPR
Discussion in 'Engine Building' started by D See 2, Mar 2, 2007.
  1. D See 2
    D See 2 Senior Member
    Baltimore, MD
    Just wanting some feedback about which rings I should go with for a GSR rebuild... Chances are, Hastings or NPR makes the rings for Honda... Any input?
  2. boostin4fun
    boostin4fun Boosted ls/vtec ohh yeah!
    Omaha
    I believe that NPR makes the rings, that is what I would go with if you are going to be using factory pistons anyways. I usually use the piston manufacturer's rings for instance when I buy SRP pistons which I use frequently I buy the JE pro seal rings which are great. But yeah I would stick with the NPR.
