Ok recently i've run into a few problems with my car. With the rings in cylinders 3 and 4 frying. I have had no cylinder wall scaring. However there is a hot spot but thats nothing a little honeing cant fix. But i am faced with the problem of rings. I have all the items to get the car running again except for rings. I am going to use the factory cast pistons. I have purchased a thicker headgasket to lower the overall compression around one whole point. I would like some aftermarket rings which would seal a little better than the factory ones. Can anyone help me out in this situation?
