piston sizing
Discussion in 'Engine Building' started by cws13, Jan 1, 2003.
  1. cws13
    cws13 Senior Member
    Athens,GA
    this is starting to confuse me. Also pertaining to another post on oil consumption. Based on the larger bore size of the LS bottom end, which alternate OEM pistons are functional in an LS block. CTR, b16, ect. The ones I have seen just used the LS pistons and I haven't really had it come up. Calesta, pissedoffsol?
  2. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    The LS has the same bore (81mm) as all the other B series except the B20b/z (84mm). All of the OEM high comp b series pistons will fit the LS bore, but only B16 pistons will fit LS rods.
  3. phunky.buddha
    Dallas / Fort Worth, TX
    Yup.
