Will swapping out my oem valves for standard size flat bottom valves affect the piston to valve clearance? I want to install some supertech high comp valves in place of my stock ones. I just want to check with u guys instead of claying the motor.
Current setup:
jdm b16a
p30 pistons
1 layer oem gasket
Current setup:
jdm b16a
p30 pistons
1 layer oem gasket
