Pistons and rods for b20z
Discussion in 'Engine Building' started by FLounder, Mar 25, 2009.
  1. FLounder
    FLounder power hungry VIP
    north palm beach, FL
    Im preparing to rebuild my engine and need some help with picking parts. for one thing, every manufacturer lists pistons for the b20b, but i cant find any that say b20z also... they are the same bore, so they should be the same right?
    so then it comes down to brands, im not really sure what kind of pistons or rods to get. the goal is somewhere around 10:1 compression ratio. the block will be decked so will affect cr slightly. i will be bolting on a jrsc with either the 8 or 10 lb pulley and im hoping for 250whp. opinions on what to get??
  2. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    Wiseco, Arias, CP, Mahle, JE, etc. I haven't really heard anything bad about them. You can simply use oversized 84mm "B18" pistons.
    For rods, the Eagle H-beams should work fine and they're probably the cheapest of the bunch. Again, many manufacturers to pick from.
  3. FLounder
    thanks, i was pretty much planning on the eagle rods... what im really wondering about is what pistons to get. i dont really like wiseco, i have had problems with them in outboard motors taht i work on.
  4. Matts96HB
    Matts96HB . Moderator VIP
    I'd grab a set of CP's. IMO, its really between CP and JE here, and CP has a different composition. JE's tend to swell more than CP's do. Just my two cents.
    1 person likes this.
  5. FLounder
    i have heard nothing but good stuff about CP pistons.... im leaning towards those.
    another question though, how much does decking the block affect cr?
  6. K2e2vin
    Raleigh, NC
    Depends on how much you take off.
  7. FLounder
    decked .010 will just bump compression up slightly right?
  8. K2e2vin
    Raleigh, NC
    Yeah; probably about .2
  9. FLounder
    update: i chose cp pistons and eagle rods.
    seems to a be a tried and true set up. thanks guys.
