ballinhatch
Any one know where i can find high compression pistons for a D16Z6?
Originally posted by HondaMoCo@Aug 24 2003, 01:48 AM
if you use 88-89 oem integra pistons, your compression ratio would be in the 12:1-12.5:1 ratio
Originally posted by ballinhatch@Aug 24 2003, 07:54 PM
i would imagine since those pistons would come out of a D16, then they prooooobably would be a little big for a 1.5.........just a thought........ :roll:
Originally posted by 92b16vx+Aug 24 2003, 07:36 PM-->ballinhatch@Aug 24 2003, 07:54 PM
Here's a thought, all D series have the same bore, 75mm. So guess what. THe difference is the stroke, example D16A6 has a 90mm stroke and the D15B7 has a 84.5mm stroke, but both have a 75mm bore.
Originally posted by hcivic.com@Aug 24 2003, 07:46 PM
why?
Originally posted by sleepergtx+Aug 24 2003, 08:54 PM-->hcivic.com@Aug 24 2003, 07:46 PM
why?
because the crankshaft is what determines the stroke of the engine.
I bet if he puts the D16 pistons on his D15 crank, he'll have the same 84.5mm stroke.
Originally posted by 92b16vx+Aug 24 2003, 08:08 PM-->Originally posted by sleepergtx@Aug 24 2003, 08:54 PM
why?
Not nescessarily, the rods are different lengths also. Example D16A6 has a 137mm rod, and a D15B7 has a 134mm rod.
