Pistons
Smonkeyboy
can you put EG9 CTR pistons in a 1st gen B-16??????
cause i found a set for $180
yes you can...that would be a very could idea actually
Yes you can, I'm currently in the process of doing it right now, myself. You will need to modify your rods however. And don't get Eagle H-beam rods if you're going this route, b/c the CTR pins don't work correctly w/ these rods. just passing along some personnel experience. Here is a link to help you w/ your mod. http://www.ff-squad.com/pistons.htm
