please correct me if wrong
searched for this now im confused, were swapping a B18a1 into a 90 crx, understand the swap, but two things confused about, ive heard that the clutch cable was ok to use stock crx clutch cable, someone said u could not on here.
Other thing was that someone said u need the purge solenoid with sensor thats
located on firewall on the integra, is this true, thanks guys.
i used a 90 teg clutch cable....and i have no idea about those sensors....my head came with a map on it so i threw the ones from the fire wall in my junk pile
i believe the clutch cable is too short, so you would need one from a 90-93 integra. buy it new from acura, this way its not stretched, like mine is.
i used my stock crx clutch cable on my swap.
straight up i used my stock cable. we took the adapter off the HF tranny and welded it onto the bell housing of the Y1 that came with the b16
