please help building a all motor LS
Discussion in 'Integra' started by cage518, Jun 16, 2010.
  1. cage518
    cage518 New Member
    i have a 94 integra, with-
    b18b1 block
    b18 head(crane cams stage 2,titanium valves and springs)
    adj cam gears
    spoon chip for ecu
    70mm throttle body
    obx-r type r style intake manifold
    aem cold air intake
    headers full 3" stainless catback exhaust
    aem light weight pulleys including underdrive pulley
    also i am swithing the b20 fuel rail and injectors over to the b18
    SO MY QUESTIONS-
    1)is it safe to use the p30 b16 pistons in the b18 block and using the stock rods from the ls?will there be any mods required?
    2)any suggestions on how to set my cams? intake degrees? exhaust degrees?
    3)my buddy told me to use the type r crank combined with the b16 pistons with the ls rods and its like a stroker motor, is this true? if it is would that be safe to do and would there be mods that would have to be made?
  2. E_SolSi
    b18b1 block -- OK
    b18 head(crane cams stage 2,titanium valves and springs) -- OK
    adj cam gears -- OK
    spoon chip for ecu -- get rid of it and get a proper tune done, the skunk2 maps are shit (i had a chip with their map before :thumbsdown: )
    70mm throttle body -- not really needed but OK
    obx-r type r style intake manifold -- OK
    aem cold air intake -- OK
    headers full 3" stainless catback exhaust -- too damn big for all motor
    aem light weight pulleys including underdrive pulley -- not a fan... but if you want em go ahead and run em
    also i am swithing the b20 fuel rail and injectors over to the b18 -- no point
    1) yes
    2) not sure what ieal would be for those
    3) dont bother
  3. three4dale
    three4dale New Member
    the frankenstroke kit you got put together wont do big difference but would be cool seen it done better than stock and yea 3 inch is way to big,,, you need back pressure 2 1/4 2 1/2 biggest but the pulleys are cool but ive heard bad things about underdrive pulley never delt with the problem personally but if its a generic underdrive it can cause vibration...
  4. phunky.buddha
    Dallas / Fort Worth, TX
    Backpressure is BS.
    The R crank with the LS rods will probably make the B16 pistons crash into your head. Stick with what you've got.
  5. Magana559
    Magana559 The Warden
    fresno Ca
    3" is fine.
    look at my build thread for info
  6. cage518
    cage518 New Member
    thanks guys
    i ended up just buying a brand new fully built block with rods, rings,bearings,high compression pistons and a sleeve job. another question that i have are b20 injectors and fuel rail bigger than that of the b18?????
    what size cc injectors do you think i'll be safe with providing the work i have done?(remember it's a completely built motor block to head)????
  7. phunky.buddha
    The fuel rail is the same- hell, the head is the same between the B20 and the B18. So are the injectors.
    For your build, I would recommend 370cc or 440cc injectors. Make absolutely sure to tune, tune, tune!
  8. Magana559
    fresno Ca
    really that big injectors? i have 310cc with no issues.
  9. 91integraRS
    91integraRS New Member
    You will be fine with b16a pistons on ls rods from what I've read on other forums on this site, as far as the type r crank goes... It will probably perform better but it won't make any type of a "stroker" kit. So is it worth it? You decide, I personally wouldn't spend the money when a stock ls crank is fine. Your 3" exhaust should be fine to back pressure is overrated. The 70mm tb is too big though, stock ls is only 62, so you should probably consider 65 or maybe even 68. I'm gonna start basically the same build soon so I would like to see how this turns out. And don't forget to check clearances running those cams with those pistons.
  10. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    3.) No. GSR/ITR cranks have shorter strokes than LS/B20 so you'll actually be de-stroking the motor and losing a tad bit of torque.
    Also, Mike, you got it backwards. GSR/ITR crank combined with LS rods(which are shorter than GSR/ITR rods) not only de-strokes your motor, it'll lower compression a whole lot making the B16 pistons' dome actually useless and just screws up combustion chamber shape. B18C rods on a LS crank would make it crash into the head; though that combination won't work anyways because the B18C rods are too narrow for B18A/B18B journals.
    Back pressure was never "rated" to begin with; only incorrectly interpreted. There's an initial pressure front from the pulses, which could be considered back-pressure(really it's a pressure wave), but there's also a negative-pressure wake that follows it. Increased back pressure means this wave will no longer be negative(hence can't take advantage of scavenging effects) and the engine does more work to push the gasses out. Scavenging effects take place with an optimal header design and cam timing; after the header you want as little resistance to flow as possible to let the header do its job well; though you also want the gasses to flow as fast as possible too. It's all a balancing act.
    As for injectors; try out CBR injectors or even RDX injectors. There's people with RDX injectors(which are 410cc) that noticed gains simply from better atomization; CBR injectors are the same design but flow less(about 290-310cc IIRC).
  11. phunky.buddha
    For the power levels I would be tuning for with that setup, I would run that size. :)
    Ah, you're right- I had it backwards.
    And as far as backpressure being "overrated" I was more talking about all the misinformation about it. What you really want is smooth laminar flow without turbulence. A variable diameter exhaust would be best. :)
  12. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    Small to big or big to small? I have 2.5" header outlet/cat to 2.25" exhaust
  13. phunky.buddha
    How much power are you pushing? If I was you, I'd match the exhaust diameter to your cat outlet diameter. There's not really much of a point in having the larger collector if you're dumping into a smaller exhaust.
  14. cage518
    cage518 New Member
    how much horsepower ideally will i have????
    i want to be in the 300's. the only place around here that tunes is synapse and they are backed up for like a month or two so if i setup today it would be 1 or 2 months from now. is there a way to tune without a dyno? also what chip would you recommend for the ecu? is there a way to post pictures in here?
  15. CAFROG
    NOR-CAL
    300hp? All motor LS? That would be quite the challenge.
    A solution to your ECU situation can be a socketed ECU so a dyno-tuner or street-tuner can program and burn a chip into your ECU.
    Its a cheaper way to get good results. Hondata and others are out there too but they can be pretty expensive
    Calesta......I just got 2.5" header/cat (I had a 2" header/cat combo before with same exhaust) I see (on ebay) a company makes fab'd pieces of stainless
    exhaust piping that are bent for Civics/Integras already and just need to be welded (to muffler/resonator/etc).......hmmm.....but stainless is expensive and I know I want mandrel bends.
  16. phunky.buddha
    Yeaaaaaaaah.... 300whp all motor is going to take the best of pretty much everything- tuning, fuel supply, breathing- everything. No chips. Hondata/Uberdata/similar or true standalone. Tune on a dyno AND street tune.
    KTeller? That seller is pretty good.
  17. Magana559
    fresno Ca
    300whp on a all motor LS isnt gonna happen. I hit 167 whp.
    plus if your gonna run on stock pistons and stock rods your not gonna make more that 200. 200 is pretty hard to reach on a LS head.
    Go LS vtec with a gsr head and ctr pistons, see whats the tallest cam you can run without smashing the valves into the pistons. Also your not gonna have any room to play with cam timing so that might restrict you from making more power.
    Next thing I would do is Spray. 100 WET shot and call it a day.
    Make sure you tune it....if you dont you will blow it all to hell.
  18. CAFROG
    NOR-CAL
  19. CAFROG
    NOR-CAL
    What did you mean by Variable Diameter in the post before??
  20. K2e2vin
    Raleigh, NC
    tapers down as you go out, similar to a reverse megaphone, and would help maintain velocity as gasses cool and contract.
