Please help... Eg rear disc conversion..
Discussion in 'Wheels / Suspension / Tires / Brakes' started by b16hatch7, Feb 8, 2009.
  1. b16hatch7
    b16hatch7 New Member
    OK i have a 1993 honda civic cx hatchback.. and i have some rear gsr disc's brake setup's that i want to put on my hatch.. the setup has everything there to bolt up to car it just didn't come with brake lines.. and yea i just got a 40/40 prop valve for the swap so i no longer need that..
    MY BIG QUESTIONS ARE WHAT BRAKES LINES DO I NEED..???
    AND WHAT MASTER CYLINDER..??
    AND WHAT E-BRAKE CABLES..???
    AND IF POSSIBLE PLEASE LIST THE PLACE'S I COULD GET THESE PARTS FROM
  2. squeals
    squeals New Member
    Charlotte, NC
    you need the e-brake cables from civic ex. you can keep your master cylinder but the brakes will feel a little spongey. junk yard? craigslist?
  3. b16hatch7
    thanks.. and yea what year civic ex..?? sorry man im new to the brake thing
  4. E_SolSi
    5th gen (92-95)
  5. 94H_Ex
    94H_Ex Under employed
    Florida
    brake lines you can custom bend and do yourself. Go to advance, napa, pep boys, autozone, or any other place and ask them about bending brake lines. They should direct you to 3 different tools, a little line cutter, a line bender, and the important one, the tool that makes flares at the end of the line. then all you do is buy the line, some conpression couplings or fittings to fit on your junctions. and you should be good.
    good luck.
