Please help EMERGENCY...
Discussion in 'General Tech and Maintenance' started by D See 2, Oct 5, 2002.
  1. D See 2
    D See 2 Senior Member
    Baltimore, MD
    ok, here's the deal... my girlfriend just bought a 94 honda civic ex automatic. one morning i went out to start it and when i turned the key, the motor went to start but then bogged right down. so i waited a second, and tried again only to find out that the motor seems like it is turning at half speed. very very slow turn over... so i proceeded to check timing to see if the timing belt jumped. but the timing was perfect. so i went and bought a new starter did the same exact thing. so then i tried the battery out of my crx... same thing. its getting fire and gas. i have never heard of a thing like this... any help would be greatly appreciated...
  2. BodyDroppedNikes
    caught in a mosh...
    uhh did u try checking the spark plugs and the spark plug wires? just a thought
  3. D See 2
    Baltimore, MD
    yea but... just to make sure... does anyone know the firing order for a 94 honda civic ex?
  4. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
    yeah i would try new plugs and/or wires, but that sounds similar to what happened when my timing belt jumped. I would definately try new plugs anyways they are cheap and a good place to start.
  5. pissedoffsol
  6. 90 accord
    90 accord Chicks dig the box Moderator VIP
    Mesa, AZ
    i had a similer problems... might wanna check your ignition relay, or take it to a honda dealer to get it diagnosed ratehr then a wild goose chase lie this
  7. slohnda
    slohnda Senior Member
    Sierra Vista, AZ
    very not swap related.. moving to misc tech.
  8. stpracer
    stpracer Senior Member
    Grove City, Pa.
    According to haynes the firing order for a civic ex 1.6 is 1-3-4-2. If I can find it in helms I'll let you know.
  9. stpracer
    Grove City, Pa.
    If it's one of those cases of worked one day - did nothing to it and it didn't work the next I'd check the distributor and/or timing belt. A plugged cat convertor is a possibility as well. Maybe run a couple of new temp grounds from the battery to block, tranny, etc...
  10. stpracer
    Grove City, Pa.
    Just another thought - got any codes??
  11. wildbillhatchbac
    wildbillhatchbac the OG VIP
    correct
