Andrew
Active Member
Ok, heres the long and skinny.
Driving up the road to the Chiropractor, granny'n it(shifting at ~2500 'cept on the freeway) and out of nowhere my car stalls on me and won't start back up!! I was at a light, and when it turned green, I let out the clutch-everythings fine- and then it stalls.. I've got plenty of gas in my tank(full), and was pressing the accelerator plenty enough NOT to stall out. Got it pushed into parking lot/towed home....
It turns over but will NOT start up.
I went through and put new spark plugs, dist. cap & rotor, and a new fuel Filter in, but no progress(but I'm sure my tired Rex didnt mind the tune up)
It still turns over, but no ingniting/combustion... hence my thoughts as to a faulty fuel pump.
Tommorow I'll go out and see if I can hear the pump turning on with the key.
If it doesnt... that would mean I have a bad pump?
I appreciate the help, fellas! I'll give you that update tomorrow after lunch..
Thanks
-Andrew
Thanks
-Andrew
