Please help me before i shoot myself in the face
Discussion in 'Wheels / Suspension / Tires / Brakes' started by smooth_criminal, Jun 15, 2005.
  1. smooth_criminal
    smooth_criminal Senior Member
    Please help me before i shoot myself in the face. I'm getting a rotaional noise coming from up front (it's not the breaks) it increases with speed, it's loudest while i'm decelerating in gear., kinda like rub, rub, rub, rub , rub. almost starting to sound like a grinding noise. Wheels aren't touching anything. i have no fucking clue what it is, i swear i wish my car would just catch on fire so i could collect the insurane.
  2. 92civicb18b1
    92civicb18b1 The Trisexual
    wheel bearings
  3. 92civicb18b1
    i wish my shitvic caught on fire, before I took all the "extras" off the insurance.
  4. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    First thing you should do is check your rotors. Make sure they aren't rubbing against the brake pad brackets (or whatever you want to call them). If that isn't the problem, it's most likely your wheel bearing. Pull the hub out and check it out. Pull them out and repack them with bearing grease. Better yet, just buy new ones, they are like $15 at AutoZone.
  5. EGProject
    EGProject YEEEEAAHHHHH
    Whitinsville, Massachusetts
    Could be a rock in the caliper. This has happened to a friend of mine, and it's annoying as hell. Easy to fix tho.
  6. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    Mine did this...the dust shields were rubbing the bottom of the rotors.
  7. CoreyR
    CoreyR Senior Member
    jack up your car and try to wiggle the wheel from top to bottom (grab it at 12 o'clock and 6 o'clock) if it feels loose like the lug nuts arent tight its the bearing if not your bearings are fine.
  8. smooth_criminal
    thanks for the info. i haven't even bothered with it yet. just went home and drank yesterday.
  9. sihatchback_RL
    sihatchback_RL Senior Member
  10. jimboburgess
    jimboburgess Go fast, Go Cheap
    nyc
    check the dust shields, it happenned to me. it is really easy to bend them so that they rub against the calipers, it is just as easy to bend them back into place.
  11. pissedoffsol
    did you shoot your self in the face yet? you haven't posted in a couple days. jsut seeing if you're still alive.
    :p
