Please Help Me!
Discussion in 'HYBRID -> EG-EK / DC' started by timEspeed, Jan 17, 2003.
  1. timEspeed
    timEspeed Senior Member
    I got a stock (not for long) '91 civic. it just started to overheat and its runnin' all screwy. It appears to be the thermostat, but at the same time this has happened my heater (a nessecity in NY during this time of year) blows cold. It doesnt make any sense to me that the car would run dangerously hot, yet blow cold air outta the heater. What the hell is wrong?!?!?
  2. solblu
    solblu Senior Member
    Ricer
    Check on the heater core. It sounds like it is involved some way.
  3. longlee
    longlee Junior Member
    make sure you have enough coolant and make sure all your hoses to the radiator are clamp on tight...i meant tight..no loose tubings at all..its probably loose so it does have pressure to return the hot coolant ...thats why you dont get hot air..
  4. farmer_jason
    farmer_jason Senior Member
    florida
    usually if a car overheats and blows cold air there is no water in it but if your gauge is reading hot it could be thermostat stuck shut or water pump. try taking thermostat out and drive it. see what it does still over heats def no circulation. water pump
  5. sharkz
    sharkz Junior Member
    first things first check out the thermostat if it's not finished, in your case it's problably stays shut as farmer_jason says. If all the easy solutions don,t work Then I would get your coolant system flushed as i've seen heater core beeing clogged which answers the cold air problem.Also there could be air in the system which usualy stays stuck in the heater core which also causes the cold air. Worst case scenario if it's stays the same after the changing of the thermostat and the rad flush , I don't want to scare you but i've seen craked head gaskets do this also. But the easy stuff will most likely solve your problem.
    Hope this could help you out. :)
  6. prawjEKt Cx
    prawjEKt Cx Senior Member
    upstate NY
    i'd say flush your coolant.... then get a new thermostat and then if it doesn't fix your problem then blame it on your heater core.... but with a flush and thermostat your looking at a whopping $20, and yeah i'm in upstate NY too, its cold as fuck
