I am having trouble with my brakes. I did a rear disc swap and I am now having a problem that I cant figure out. I swap rear discs from a teg, replaced the booster with a new one, got a mc from a yard and ordered a 4040 valve from ebay. After I did the swap my rear calipers started sticking so I replaced them and now that is ok. Now my front calipers are rubbing. I replaced them thinking that would solve the problem. It got better but not fixed. When I drive around I can tell that they are rubbing because I get poor throttle response like i am ridding the brakes. The strange thing is that it is not constant. Sometimes it will get steadilly tighter as I drive, then when I turn the car off for a bit they release and I can drive around for a long time and they will be fine. Also when it does tighten up it seems to be tighter on the front passenger side, sometimes making the car pull right. I know it could be the mc but when ever I do the checks from the helms manual everything seems ok. Could it be the prop valve and if so how can I check that? I am really stumped and could use some help. Thanx in advance for any advice.
