Ok I decided to start out with a mini me swap on my d16a6, I found a z6 head comes complete with throttle body, intake manifold, fuel rail, injectors, distributor, and wire harness. Its all off a 95 Del Sol.
I found this the most informative out of all I've looked at, but need some clarifacation :http://crx.honda-perf.org/articles/z6swap/z6swap.html
1. If I get a computer that goes with this swap do I still need a Vtec controller? What computer should I look out for?
2. The car has a new timing belt, can I use it or not? If not which timing belt do I need?
3. Will my exaust manifold on the d16a6 work with the z6 head?
4. Is it worth port and polishing this head or does it flow good as it is?
Thanks for your replies. -crombie09
